Results 1 to 1 of 1
Thread: hELLO...!!!!
26-06-2006, 08:28 PM #1
hELLO...!!!!
hI ....!!!!
THIS IS MY FIRST POST ....MY PRIMARY LANGUAGE IS SPANISH AND MY JOB FUNCTION IS TO MANTAIN A REEFER FLEET UP AND RUNNING..... FEW DAYS AGO I INTENDED TO CONVERT A SINGLE PHASE THERMO KING UNIT INTO A THREE FASE ONE AND WHEN I INSTALLED A 12 V.C.D. MOTOR FROM THE DIODES BRIDGE OF THE TRANSFORMER 220/12 V.C.D. THE MOTOR WAS RUNNING PROPERLY FOUR HOURS AND THEN THE TRANSFORMER GOT EXTREMALLY HOT AND FUMES FILLED THE CONTROL CABINET....
READINGS BEFORE CONNECTING THE MOTOR WAS 12.7 VOLTS AND WITH MOTOR WAS 11.7 THE TRANSFORMER CAPACITY IS 180 VA AND THE AMPS IN THE SECONDARY ARE 5.0 AND THE MOTOR PLATE AMPS ARE 5 TOO.
