Results 1 to 1 of 1
Thread: Sanyo E09 fault
24-01-2022, 10:21 AM #1
Sanyo E09 fault
Hi all,
Ive an E09 issue on a Sanyo system which I’m not overly familiar with. I’ve one controller in a riser which is the main one controlling all functions on 4 splits. Then their is sub controllers in each room to change temps and on/off. However one is flashing E09. As I understand it the address is most probably duplicated but how do I change it and what too? I know on the Toshibas it’s simple, just a dip switch on the rear of the controller you set to follow, but I know Sanyos hold a lot of their info in the eprom chip and can be a nuisance ? Any advice would be much appreciated.
Chris.
