Thread: Daikin 51e/140
    Jan 2022
    sweden
    Post Daikin 51e/140
    Hello guys
    iam new here, we have problem whit: A3 Malfunction of drain level control system.
    this came after change of indoor module.
    5,668
    Re: Daikin 51e/140
    Check that the drain level sensor is connected correctly to the new pcb board.
    Look for the wiring diagram on the inside of the indoor electrical cover and it will reference the sensor wiring and the X?? connector on the pcb
    Jan 2022
    sweden
    Re: Daikin 51e/140
    thx, i will check this first.
    Jan 2022
    sweden
    Re: Daikin 51e/140
    Hello. I did check the drain lvl sensor and i found a missing bridge connector.
    Now its trowing another fault U0-04. its how does i reset this one?
    best regards
    5,668
    Re: Daikin 51e/140
    Looks like a refrigerant shortage
    https://www.google.co.uk/url?sa=t&so...QVuC8dmtXCGsV9
    Jan 2022
    sweden
    Re: Daikin 51e/140
    hi again, thx for input.
    i have checked the instruction manual and here is no U0-04
    The nearst is U4: Wiring error between indoor and outdoor unit. Or indoor and outdoor printed circuit board failure.
    5,668
    Re: Daikin 51e/140
    Look at the top of page 3 of the link I have posted U0-04 Refrigerant Shortage or Blockage
    Jan 2022
    sweden
    Re: Daikin 51e/140
    hmm.. yes i see
    how to solve this U4 issue, any thoughts?
    it has new cards(pcb) in outdoor and indoor unit.
    5,668
    Re: Daikin 51e/140
    U4 is a failure of data transmisson between the indoor and outdoor pcbs
    Check the wiring and make sure terminal's 1, 2 and 3 are correctly terminated at each end to rule out mis-wiring. Also check the wiring in any local isolators and high limit switch if you have an indoor condensate pump.
    Jan 2022
    sweden
    Re: Daikin 51e/140
    thanks ill have to check the wiring this weekand.
    What about U0-04?
    5,668
    Re: Daikin 51e/140
    Quote Originally Posted by Pirre View Post
    What about U0-04?
    Unfortunately you will need someone with the correct tools and knowledge to solve that one
Tags for this Thread
