Results 1 to 2 of 2
Thread: Frigorex FV-650
    Jan 2022
    Bulgaria
    1
    Frigorex FV-650
    Hello, does anyone knows if there is a way to turn on the lights without turning on the cooling on FV-650? Thank you in advance.
    ireland
    1,452
    41
    Re: Frigorex FV-650
    Should be a seperate switch on it, try turning stat off or if digital controller set set point high as you can.
Tags for this Thread
