Thread: Frigorex FV-650
03-01-2022, 04:47 PM #1
Frigorex FV-650
Hello, does anyone knows if there is a way to turn on the lights without turning on the cooling on FV-650? Thank you in advance.
03-01-2022, 06:49 PM #2
Re: Frigorex FV-650
Should be a seperate switch on it, try turning stat off or if digital controller set set point high as you can.
