Results 1 to 2 of 2
    Oct 2021
    Spain
    1
    Gree split air con (wfi), can I set higher minimum temperature?
    I have two different Gree split air con units (WiFi), is there anyway I can assure that the temperature can't be set below 22 degrees C?
    Thank
    Oct 2001
    Nottingham UK
    5,668
    Re: Gree split air con (wfi), can I set higher minimum temperature?
    Set it to 22 and then take the controller away ( assuming that it is a hand held and not hard wired)
