Results 1 to 2 of 2
    Jul 2021
    2
    True NEK6165U Fridge
    Have this True NEK6165U fridge that i'm looking at, When turn on at mains compressor starts up and runs for between 3-5 mins then cuts out. klixon been replaced still the same, would this be controller fault?
    Feb 2011
    scotland
    454
    Re: True NEK6165U Fridge
    Is it the klixon thats stopping the compressor? If so check the compressor and its electrical components are working correctly, like the relay and capacitors if it has them. And that the supply/voltage to the comp is correct.
