    Mar 2006
    Midlands
    29
    Mitsubishi PUHZ-ZRP140VKA condenser
    Hi all, a small shout for help please.
    I have a Mitsubishi AC that keeps freezing up.
    The condenser is turning into a solid block of ice and smashing up the fan blades. No fault codes, it will just run untill the damage is done!
    If the site are using the AC on constant heating mode, do Mitsubishi have a internal defrost command ? If so what thermistor activates this?
    TIA for any help
    5,733
    Re: Mitsubishi PUHZ-ZRP140VKA condenser
    Lots of things to check:
    Gas charge
    Outdoor thermister values
    Coil thermister values
    Etc.
    Here's a link to the Service Manual http://www.mitsubi****ech.co.uk/Data...SM_OCH527C.pdf
    Mar 2006
    Midlands
    29
    Cheers Frank, I suspected thermistor issues, as someone has butchered it before! Sorry, I can't open the attachment!
    5,733
    It's a web site link not an attachment. Looks like it didn't paste correctly. I'll have a look
    75
    11,192
    It's the site language editor that does it Frank, your link was fine before the astericks struck.
    Try this https://tinyurl.com/9x9m7za5
    Apr 2008
    Southampton, England
    49
    1,044
    35
    Outdoor coil probe main suspect if not going into defrost.
    Mar 2006
    Midlands
    29
    Thankyou Brian, I've got the info downloaded 👍🏼
    Tayters, again thanks, I think we're on the same page. Thermistor issues.
    I was unsure as the weather or not, the condenser still defrosted its self when on "heat mode" or "auto cycle" I guess if the coil probe is reading correctly, it should defrost either way ?
