Thread: Buffer Tank
    Feb 2012
    libya
    41
    94
    13
    Buffer Tank
    Please what is the right size for Chilled Water Buffer Tank to be use with Climaveneta Model: ERACS2-WQ/s 2502
    Thank you
    11,025
    Re: Buffer Tank
    It depends on system capacity mostly, however
    According to York: V=N x 60 x Z / 4.18dt
    V= total system water content (Litres)
    N= chillers first capacity step (kW)
    Z= minimum allowable running time (min 5 mins)
    dt= temp difference at minimum partload condition (say 2 deg C.).
    This allows the chiller to operate smoothly at low load capacities and should provide sufficient thermal storage to give at least 5 mins operation after the machine has stopped running. This ensures the equipment doesn't keep stopping and starting at low load conditions..
    Feb 2012
    libya
    41
    94
    13
    Re: Buffer Tank
    if the chiller capacity 633 Kw @ 7/12 deg.C, So
    V= 633*60*5/4.18*2 = 22715 liters. Is this right ? i think too much quantity
    and please this tank should divide type with primary pump and secondary or can be normal tank like they recommend in attached file
    Attached Files Attached Files
    11,025
    Re: Buffer Tank
    You have used that calculation based on the maximum capacity whereas the chiller minimum is 25% and the minimum dt is 3⁰K.
    By my calc that gives a figure of 3875 litres.
    The chiller manufacturer should be able to give you a recommendation.
    Oct 2020
    india
    13
    Re: Buffer Tank
    Consult factory for sizes, dimensions and specifications. Chilled water buffer tanks are essential components for chiller systems.
    Feb 2012
    libya
    41
    94
    13
    Re: Buffer Tank
    is it necessary to be divided
