Results 1 to 11 of 11
Thread: X430
    Apr 2006
    U.K
    11
    X430
    Can anyone tell me the reason for oil pump failures on X430 compressors? That is the key that rolls on the shaft. I remeber the problem in the past and cant remember the solution. I have just been in contact with Australia and they have been checking the pumps on a regulaur basis to change the pump before failure occures. I thought that TK had solved this problem.
    Jan 2003
    East Anglia
    1,160
    Re: X430
    i Didn't realise there was a diffinative answer to oil pump failures, i just assumed it was down to wear and tear like the shaft seals. The old seals 22-778 never seamed to leak at all but the new ones for some reason will let some oil past ?
    Is it possible play in the shaft can cause to pin in the pump to fail.
    At the end of the day, if i am changing a shaft seal, which is a fairly common proceduren and you already have the compressor off it only takes 5 mins to pull the oil pump off at the same time anyway
    I was unaware there was a pump issue, i have never had one fail, i have just replaced worn ones when doing a rebuild.
    fatboy
    Apr 2006
    U.K
    11
    Re: X430
    Thanks fatboy, there has been a problem with the compressors for the last 3 years at least around the world and I am waiting on some info to come through. I do know that TK has issued a bulletin about it.
    Jan 2003
    East Anglia
    1,160
    Re: X430
    Hi Duncan,
    If there is an issue Reeferjon is the top man over here when it comes to TK, Hopefully he will know something about it
    Fatboy
    Jun 2001
    N.Ireland
    1,630
    Re: X430
    Quote Originally Posted by rdocwra
    fatboy
    That would be the secret Replace it just before it fails, not wait until failure occurs.
    Kind Regards Andy
    Mar 2005
    Austraia
    48
    Re: X430
    Quote Originally Posted by duncan
    Hi it has something to do with loading on the compressor input shaft/clutch which puts to much load on the oil pump
    Martin
    Jan 2003
    East Anglia
    1,160
    Re: X430
    Quote Originally Posted by thermo690
    Hi it has something to do with loading on the compressor in put shaft/clutch which puts to much load on the oil pump
    Martin
    Hi Martin,
    I Know TK did make a big thing about using belt tensioner tools on the compressor belts (OH REALLY WHO HAS THEM) .
    I think when the new style electic motor brackets came in with the 17mm adjuster people were pulling them too tight and causing too much strain on the clutch/compressor shaft. Saying that, it's easier to use them than the old style long bar on top of the electric motor trying to get the belts tensioned
    fatboy
    Willy's Avatar
    Willy Guest
    Re: X430
    Hi Duncan
    There was a major issue over the reliability of the original oil pumps and several bulletins were issued over the years regarding this, I have attached a brief history of the problem and where TK are now with it.
    Cheers...
    Attached Files Attached Files
    Nov 2001
    Shropshire
    59
    260
    23
    Re: X430
    Nice one Willy.....TBH that about sum's it up....new keys, wear surfaces and drive shafts are now in production...........Last SMC saw the suggested release of a new cast iron pump 3rdQ 06.....This will also lead to new body and bearings.
    Main point....when ever you remove a comp ALWAYS remove the oil pump as soon as its on the bench and in any event prior to clutch work.
    Jan 2003
    East Anglia
    1,160
    Re: X430
    Hi Guys,
    Whats the latest official line on shaft play on X430's
    Originally, we we rebuilding x430's every 3000 hours as there was play in them but then someone at MTK said some play was acceptable (Just like oil under the new shaft seals was acceptable ).
    Whats the line now.
    Fatboy
    Apr 2006
    U.K
    11
    Re: X430
    Willy thanks for that. I new that there was something floating about. If there is anything I can help with let me know.
