Results 1 to 13 of 13
Thread: corrosion
22-05-2006, 02:25 PM #1
corrosion
G'day all.
I live on a coastal area of southern Australia. We install and service a lot of wall mount a/c units of varying brands.
What I have noticed is a tendency for some of the outdoor units in close proximity of the ocean to show signs of corrosion after a few years.
Was wondering if any other members have had similar problems and what they might have done to remedy the situation.
I have already had the suggestion of using a lanolin spray for treating the units and one particular unit that we did repair we ended up using fish oil to treat it.
Any comments would be appreciated.
22-05-2006, 03:58 PM #2
Re: corrosion
Coils can be supplied with various surface treatments, like blygold or epoxy paint, able to withstand weather and ambient aggression at various levels of protection.
22-05-2006, 04:09 PM #3
Re: corrosion
Hi Temprite,
Here is a link that might provide some useful information.
http://www.electrofin.com/
Admittedly, this is a US company but I thought it might provide some ideas on an alternative you might be able to source within Australia.
22-05-2006, 06:37 PM #4
Re: corrosion
We live also very near the sea and we spray a zinc spray througfh the fins (we use teh spray from Zinga which is more then 99% zinc)
The heat transfer isn't affected and the zinc will sacrifice itself when corroding.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
23-05-2006, 11:00 AM #5
Re: corrosion
Originally Posted by Peter_1
23-05-2006, 12:42 PM #6
Re: corrosion
Thanks for the replies everyone.
The coils have been ok since most reputable manufacturers treat them anyway.
Problem is the casing and more so the feet and base.
Have some where the feet have nearly collapsed after about 5 years.
23-05-2006, 05:38 PM #7
Re: corrosion
Here is a link for cold galvanizing spray
http://www.zrcworldwide.com/p_zrc.asp
http://www.zrcworldwide.com/pdfs/t_g...pplication.pdf
The mermaid is quite pretty. Why is she hiding in every picture?
23-05-2006, 07:17 PM #8
Re: corrosion
Originally Posted by BESC5240
It's only a matter of picking the right one.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
23-05-2006, 07:17 PM #9
Re: corrosion
Originally Posted by US IcemanIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
30-05-2006, 09:32 PM #10
Re: corrosion
Hi Temprite
I got first hand experience of the rust and the corrosion that it causes, I use a product called TECTYL, mostly used in the automotive industry to treat the underside of vehicles as a sealant, goes on and sticks like bubblegum to a monkeys backside, last about 2 years in the sun if sprayed nice and thick, speak to your panelbeater about what they use, its oil based just runnier than tar, but same principal
30-05-2006, 10:34 PM #11
Re: corrosion
Thanks Andre.
17-06-2006, 11:44 PM #12
Re: corrosion
Have a severe salt corrosion problem here, I must have seen almost every coating out there, herestite , bronzglo, adsil, electrofin, sea coat etc.
What I found works best is to avoid the dissimilar metals in the first place and therefore not worry about the electrolytes.
The all aluminum spine fin coils (old GE design) currently used by Trane and American Standard will outlast any copper tube aluminum fin coil with a coating.
Washing an untreated coil on a regular basis extends coil life.
19-06-2006, 01:54 AM #13
Re: corrosion
FISH OIL? who's pullin who's donga!
Stress Corrosion Cracking in NH3 Vessels
By US Iceman in forum NH3Replies: 26Last Post: 15-02-2008, 06:41 PM -
Corrosion for your viewing pleasure :)
By Tycho in forum IndustrialReplies: 10Last Post: 09-02-2006, 03:32 AM -
Corrosion.
By romaurie in forum IndustrialReplies: 4Last Post: 27-11-2005, 10:57 PM -
Corrosion...What corrosion?
By SteveDixey in forum IndustrialReplies: 0Last Post: 04-08-2003, 05:41 PM
