Results 1 to 26 of 26
Thread: R-22 conversion
20-05-2006, 10:51 PM #1
R-22 conversion
Has anyone converted Carrier's that are on R-22 to another refrigerant? Speaking of mostly Ultra's. With the R-22 soon going out of style, just wondering what would be used. I am guessing that R-404a would have close to the same pressures?
I don't think that R-22 is banned here for another 5 years??
Any info would be great.
ReeferMadness
20-05-2006, 11:18 PM #2
Re: R-22 conversion
Hi Reefermadness,
Unless anything has changed we should have R22 till 2012.
Most new units now come on R404 so by the time we loose R22 the units on it will be very old.
I still remember the problems we had with Carrier when 12 was phased out. Blown t-bird compressors all over the country because the interim gas caused oil migration at low temp (Think it was 49 although bad memory)
R407 is the new gas on a/c replacing 22 but i don't know how it would get on for low temps.
New expansion valve and change comp oil to polyolester might work for R404 if the compressors can cope.
My honest opinion is that nothing concrete will happen until 2011, while 22 is still available there is no push to change thing
I dont know how old you are but if you remeber the change over from r12/R205 this only happened at the very last minute and thing 22 will go the same way
regards
Fatboy
21-05-2006, 09:45 AM #3
Re: R-22 conversion
check the data of your load capacity and check your compressor if applicable to your desire refrigerant. get the refrigerant changeover procedure from your local compressor dealer.
21-05-2006, 10:42 AM #4
Re: R-22 conversion
Isceon MO59 and MO29 from DuPont is a drop in replacement for R22, and it a HFC.
http://refrigerants.dupont.com/Suva/en_US/pdf/k10927.pdfLast edited by NoNickName; 21-05-2006 at 10:49 AM.
21-05-2006, 05:48 PM #5
Re: R-22 conversion
Ok, i get the picture. Change the oil, drier, TXV to R-404a head and off to the races. Not hard since Carrier still mad the Ultra with R-404a. I was just wondering since I still convert a unit about once a month. This should have been over with years ago, but around here, old stuff thrives. Lots of SB II(I) MAX still on R-502, not to mention T-Birds on R-500.
Thanks for the insight,
ReeferMadness
21-05-2006, 06:28 PM #6
Re: R-22 conversion
Hi Reefermadness
We have a saying this side of the pond " If it aint broke don't fix it "
Over here you will still find some units on R12/R502 and while they are still running then you don't touch them. Obviously as soon as they have a gas leak or problem that requires removal of gas then you can't replace that gas and have to modify.
These old Carrier units just go on and on, i wonder how may vectors will still run when they are 20 years old
Fatboy
22-05-2006, 11:54 AM #7
Re: R-22 conversion
I remeber many years ago when Fujitsu were retro fitting thier Splits using another company to charge with 407C
Basicly we had a customer who wanted 407C units ( this was about 4 years ago now) Fujistu didnt have any 407C units, so out came the R22 and in went the 407C, needless to say all the compressors failed after 13 months !
And guess who didnt want to know ? :lol:
R22, if only we had more people that took care, we would not be in the state we are now.
29-05-2006, 11:04 AM #8
Re: R-22 conversion
Please remember when changing to R404a the system needs to be flushed, all the sv's need to be changed, TX valve to be changed, new shaft seal, new valve plates. We did many of these in South Africa and learnt the hard way. Dont forget that there is also a quench valve on the r22 system and the R404a system doesnt have one. We did leave the valves in on our conversions.
29-05-2006, 11:17 AM #9
Re: R-22 conversion
if you remove the gas from an old system to carry out some work. legally, can you put that gas back into the system when the work is complete if the gas is say r12 or r502
29-05-2006, 03:28 PM #10
Re: R-22 conversion
Originally Posted by smoggy
regards
Fayboy
30-06-2006, 05:29 PM #11
Re: R-22 conversion
R 407 will be the replacement for R22 I think.
30-06-2006, 05:47 PM #12
Re: R-22 conversion
R507 I meant not 407
01-07-2006, 07:07 AM #13
Re: R-22 conversion
hi dear
find all replacement in this link:
www.harpintl.com/guide.htm
regards
afeef
18-08-2009, 01:15 PM #14
Re: R-22 conversion
Do we have any further thoughts on this as its getting closer......
Practice Truth, Fear Nothing.
18-08-2009, 04:55 PM #15
18-08-2009, 04:58 PM #16
18-08-2009, 05:00 PM #17
Re: R-22 conversion
I was speaking to a bloke at a Climate Centre last week who said there are two replacements for R22. Drop-in replacements that is: R417a and R422d. Not that I've tried them, but it will all kick off next year.
A lot of customers think we can just change to R407c, but the oils are different, and the retrofit would be risky.
18-08-2009, 06:16 PM #18
Re: R-22 conversion
Accordeing to monterial treaty for the phase out of refrigerant 22. It will be phased out totally by the end of year 2030
19-08-2009, 02:40 AM #19
19-08-2009, 03:16 AM #20
Re: R-22 conversion
here in canada there are still people with R12 in their car air conditioners!!!!! I have fixed man old R12 container reefers. We still sell R12 in the transport industry.
19-08-2009, 10:42 AM #21
19-08-2009, 02:41 PM #22
Re: R-22 conversion
Here is the replace for R-22 base on National refrigerants
"R-407C, R-410A, R-417A" I don't know if every country are the same!
19-08-2009, 07:30 PM #23
21-08-2009, 03:46 AM #24
22-08-2009, 01:30 PM #25
Re: R-22 conversion
I would think if you were going from R22 to R404a you would also have to install a heat exchanger, as R22 Carriers don't run a heat exchanger.
24-08-2009, 02:12 AM #26
Re: R-22 conversion
I'm with you Latte! You guys are creating a Frankenstein here. Have you checked for a heat exchanger like Boss said? R404 units have them. Does yours?
I would leave her alone!
Free conversion software I use
By Peter_1 in forum Tools and CalculatorsReplies: 13Last Post: 23-12-2010, 11:57 AM -
Horsepower to tons/ref. conversion ?
By Hank Hill in forum Tools and CalculatorsReplies: 8Last Post: 15-05-2010, 07:42 PM -
Pressure to Temperature Conversion
By cryptojoe in forum Technical SpeculationsReplies: 5Last Post: 13-04-2010, 12:42 PM -
Propane Refrigerator Conversion
By zolar1 in forum RefrigerantsReplies: 26Last Post: 04-02-2007, 03:42 AM -
R12 to R134A conversion
By northern-tech in forum CommercialReplies: 8Last Post: 26-06-2006, 06:24 PM
