Threaded View
14-05-2006, 04:15 PM #1
can a r22 split system condensing unit be used to cool a display fridge
just wandering how well a standard outdoor unit from a split system aircon will work to cool a display fridge where the liquid line is direct expanded into the suction line which "snaked" along the stainless steel base of the display case. The gas used is r22 and the temp maintained is desird to be 3 deg c.
The reason this may want to be trialed is its extremely cheap to buy a split aircon ($250) for 2kw capacity (with a good matsu****a compressor)as oposed to a proper condensing unit for the dispaly fridge
Daikin fault codes
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
M I T S U S H I T A ac unit with no condensing unit
By Chinua in forum Air ConditioningReplies: 2Last Post: 28-07-2006, 06:54 PM -
Heater/cooler split system A/C electrical connections help pls!
By JamesQB in forum Air ConditioningReplies: 5Last Post: 22-06-2005, 07:41 PM -
Matching Evaporator with Condensing Unit
By Abe in forum Technical DiscussionsReplies: 12Last Post: 25-07-2001, 08:57 AM
