Thread: information reqired
14-05-2006, 12:49 PM #1
information reqired
Could anyone tell me the advantages/disadvantages of the following rotary/scew/ricprocating/centrfugal/scroll compressors.As i require this information for my course work
regards daba
14-05-2006, 03:37 PM #2
Re: information reqired
Reciprocating compressor
When Reciprocating compressor classified by structure :
open type
advantages:
1.dismantling and inspection are possible
2. revolving speed is variable
3. engine driven is possible
dis :
1. dimensions of units are larger than that of compressors having the same horsepower
2. shaft seal is neccesary and there is possibility of gas leakage
semi hermetic type :
adv:
1. dismantling and inspection are possible
2. no gas leaks from shaft seal
3. moving part are not exposed
4. running noise are smaller that one of the open type
dis :
1. revolving speed is fixed
hermetic type :
adv:
1. compact and light
2. no gas leaks
4. running noise is low
dis :
1. dismantling is impossible when damaged. a whole compressor should be replaced
2. motor is feee from moisture or dust
Rotary Compressor
adv:
1. since rotary is a high-speed, large displacement machine, its saving in manufacturing cost.
dis:
1. best for low pressure ratio
Centrifugal compressor :
used for refrigerants having large vapor volumes per tons of refrigeration and high mollecular weights.
Reciprocating compressor nomally used for small and medium ranges of tonnages, centrifugal compressor primarily for larger tonnage.
please correct me if i am wrong.
any additional?
rgds,
14-05-2006, 08:34 PM #3
Hi, daba welcome
take a look at this page:
http://www.reedlink.com/ProductInfo~...mpressors.html
and here also:
http://www.carlylecompressor.com/cor...TI9588,00.html
Come back with comments
Best regrds,
JosipLast edited by Josip; 14-05-2006 at 10:27 PM. Reason: add link
Fundamental information
By US Iceman in forum FundamentalsReplies: 12Last Post: 24-01-2010, 06:25 PM -
information on an old Air temp A/C
By Bahaaeldeen in forum Refrigeration BooksReplies: 3Last Post: 09-05-2006, 12:49 PM -
auxiliary components information
By mohamed khamis in forum Tools and CalculatorsReplies: 2Last Post: 27-04-2006, 01:20 PM -
Information on Hussmann enviropacks
By tonydeith in forum Supermarket RefrigerationReplies: 0Last Post: 25-04-2006, 01:22 PM -
Information on frost top prep table
By kengineering in forum CommercialReplies: 15Last Post: 08-02-2006, 09:58 AM
