Results 1 to 10 of 10
Thread: Difference between compressors
13-05-2006, 07:38 PM #1
Hi guys I have SMC-180 compressors and by mistake I had got spare parts for T/ SMC-180, what is it the difference between this compressors
Thanks for helpLast edited by Siniša Mirilov; 20-06-2006 at 01:11 PM.
13-05-2006, 08:50 PM #2
Re: Difference between compressors
Well Not every one here is "That" happy but use meer guys may be able to help sadely I'm not one of em as I'm the newb here, sorry mate.
(I meant this as a friendly humour bite,)Last edited by The MG Pony; 15-05-2006 at 08:06 PM.
13-05-2006, 09:05 PM #3
no difference
you can use spare parts on both types. What spares you ordered?
Best regards,
Josip
13-05-2006, 09:16 PM #4
Hi Sinisa
the TSMC is a two stage compressor for low temp. Spares are quite similar, extra manifold connections, needle bearings in the high stage piston bearings, different discharge valve holders.
Kind Regards. AndyIf you can't fix it leave it that no one else will:rolleyes:
13-05-2006, 10:55 PM #5
Originally Posted by Siniša Mirilov
I've got a feeling I made a similar mistake in the past, except ordering an SMC piston instead of TSMC. I only noticed the mistake when the crank didn't turn over once we put the discharge valve and top cover on. Based on that, if you use TSMC pistons, you'll get a larger gas space a piston Top Dead Centre.
Steve
14-05-2006, 03:56 PM #6
Originally Posted by SteveDixey
You can have S, L and E type corresponding to different lenght of pistons and that is very important when ordering spare parts. You must write down type of compressor, no of cylinders and execution S,L or E and production year.
Sabroe made a lot of changes in code numbers, spare part kits and sets.
Request for spare parts must be very correct to get an adequate answer and spare parts
Best regrds,
Josip
14-05-2006, 10:33 PM #7
Originally Posted by Josip
Kind regards
14-05-2006, 10:35 PM #8
Kind regarts
14-05-2006, 10:37 PM #9
Originally Posted by Andy
Kind regards
15-05-2006, 01:05 AM #10
Hi SM,
If I could recalled, you must specify Mark 1, Mark 2 or Mark 3 against the SMC models
Cheerio lad
Manuerop Compressors
By john doersom in forum CommercialReplies: 39Last Post: 22-07-2006, 01:30 PM -
Price Of Refrigeration Compressors
By justin4236 in forum Supermarket RefrigerationReplies: 5Last Post: 08-09-2005, 01:38 PM -
Compressor's volume efficiency
By John McGru in forum FundamentalsReplies: 0Last Post: 16-02-2004, 08:44 AM
