Thread: Cold room door handle needed
08-08-2016, 11:40 PM #1
Hi need some help finding a cold room door handle. A friend recently purchased a cold room for use at home as he does a bit of deer stalking. The cold room came without a handle. I have attached a pic of the recess in the door where the handle was. The shelving that came with the room is fermod shelving. I checked their web site to see if there was a handle that would match this, but I didn't see anything which might. Would anybody know by looking at the photo what sort of handle would fit this door recess. There is no manufactures name plate on the door or the room. The picture below is shown in landscape view, it should be in portrait or rotated clockwise.
09-08-2016, 04:27 PM #2
Re: Cold room door handle needed
09-08-2016, 06:17 PM #3
http://kilkennycooling.com/wp-conten...PartsGuide.pdf
I think it is the 5000 series set you need. Easy to fit. Other wise it will be a Ryan http://www.ryanchilling.ie/accessories A001Mostly found in the southern part of this green and pleasant land.
09-08-2016, 10:57 PM #4
The Ryan chilling A001 looks like the one. I will ask them for the tech specs on this, but i am fairly sure that is the one. Thank you both for your help.
I tried to register on the Ryan chilling site, but can't seem to register an error page keeps coming up. I will give them a call in the morning. Thanks again.
12-08-2016, 10:47 AM #5
Hi Al,
You were right with the Ryan chilling handle A001.
Thanks again for your help
12-08-2016, 01:21 PM #6
12-08-2016, 06:36 PM #7
I'm going to print out and frame that one Chemi)
