Results 1 to 1 of 1
Thread: Budget figures
05-05-2006, 02:56 PM #1
Budget figures
Does anyone have a rule of thumb for budgeting:
Closed circuit cooling tower $ per ton/ sqr ft/ ?
Low temp tempering boiler $ per Mbtu/ sqr ft/ ?
Loop and pumps $ per ton/ sqr ft/?
Again, this is only for budget numbers. The system is a multiple water to air heat pump on a main water loop configuration with cooling tower, tempering boiler(gas) and about 50 heat pumps.
Any info would be apprecaited.
Best regards...
