Results 1 to 10 of 10
Thread: KW usage
    May 2009
    New Zealand
    KW usage
    The question came up recently about how much power my Fujitsu invertor actually uses. It's 4.8KW on heating but the thought was once it gets the room up to temperature does it begin to save electricity? So the thought was maybe the fan and the compressor can go into reduced power consumption modes. What can one expect? Thanks
    Aug 2009
    Dartford
    34
    88
    15
    Re: KW usage
    If it's inverter the compressor will ramp up and down pulling less amps
    Oct 2007
    manchester
    5,639
    45
    Re: KW usage
    put the indoor fan speed in auto- will slow down when it reaches setpoint
    May 2009
    New Zealand
    Re: KW usage
    Quote Originally Posted by Deano240 View Post
    Thanks. Yes, I can hear the compressor ramping up/down... and that should equate to less amps as you say.
    Quote Originally Posted by install monkey View Post
    Thanks for the thought. Yep, mine is set to that now and yes the fan speed varies I suppose dependent on the work load. Actually the fan speed can be right whacky in behavior, sometimes it starts racing for no apparent reason.
    Are we talking my 4.8KW figure halving on light load or could it get down to say 1KW when it was doing almost no work, like effortlessly maintaining setpoint? I suppose I'm trying to understand in what situations I'm better off turning the thing off altogether.
    Thanks!
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: KW usage
    A/c's are there to Cool or Heat just to satisfy the indoor temperature sensor via a resistance value. Air-conditioners have no idea of their current power consumption.
    Oct 2007
    jersey channel islands
    186
    Re: KW usage
    I think. The sales blurb. Used to say in heating one kw spent gave. Two kw free.
    As it is a very. Efficent way of heating .
    But in cooling. It was one kw spent one kw used .
    i have a multi split. One wallmount in lounge and one in main bedroom, only heat. The lounge in winter as. We have heat recovery too, a all electric house ,no gas , wife home all day
    so she want to be toasted,and only £400 ish. For our worst quater of electricity.
    the walls are rammed with insulation too.
    best thing we ever did was aircon the home
    May 2009
    New Zealand
    Re: KW usage
    Somewhere I have a digital power usage meter. It's a Chinese made item that fits over the feed wire and records current use. If I fit this to the heat pump wiring it will tell the full story... no bull, hype or sales blurb.
    It would be interesting. Hoping to do it soon. Now where is that thing...
    Auckland
    74
    3,357
    38
    Re: KW usage
    Tech Rentals hire out accurate Kwhr certified check meters. You will have to compare indoor and out door temps as well as power consumed for an effective efficiency performance.
    The latest model blurb for heat pumps is a 4:1 average COP on heating.
    Let us know how you go with results.
    Aug 2008
    Auckland
    55
    259
    21
    Re: KW usage
    I've always had an interest in this sort of discussion. Always, sort of, maybe, when I get round to it, which will probably be never, wanted to carry out an exercise on this. Possibly get 2 exact same rooms and put a fixed speed AC in one and an inverter in the other, both same nominal kW rating, wire them up for monitoring and see what they produce, draw amps etc.
    But as I say, when I get round to it.....
    May 2009
    New Zealand
    Re: KW usage
    Turns out my meter doesn't work so I can't monitor it at this time...
