    mattsaidbye's Avatar
    mattsaidbye Guest
    How much ***** for Coke machine
    Hi there, my first post....
    I am fixing my old Dixie-Narco 501t Coke machine.
    I have bought a compressor on ebay, and now I am wondering on how to charge it up?
    I was considering using ENVIRO-SAFE ES-12a from
    http://autorefrigerants.us/
    Since the compressor is originally an R-12 type, I was wondering if this would work, and how much of the refrigerant would be needed, and how much and what kind of oil?
    The compressor can be seen here:
    http://cgi.ebay.com/ws/eBayISAPI.dll...611839104&rd=1
    Any help would be greatly appreciated!
    Matt
    Oct 2003
    61
    5,635
    33
    Re: How much ***** for Coke machine
    My first concern is...is the unit suited for you Coke machine?
    This unit seems on a firstsight far too big for it.
    Has it a receiver?
    Then,..if it shoud suit..do you have the proper equipment to instal it? Vacuum pump, an acetlylen/oxygen torch, a manifold, ....?
    You can't calculate this amount, you have to add some amount and monitor your gauges closely. If your gauges tells you (!) that some gas had to bed add, then you have to add some.
    I should start with 500 gr
    Feb 2006
    derbyshire
    610
    if you have little or no experience of this trade it could be dangerous telling you,let a engineer do it.
    75
    11,194
    59
    The simple but perhaps too easy answer is RTFM or have a look at the data plate.
    Jan 2006
    Adelaide , Australia
    192
    Thumbs down Re: How much ***** for Coke machine - have a guess
    Quote Originally Posted by old gas bottle
    I agree with the above quote , but then you can learn a lot from experience . Perhaps you can find some propane based refrigerants and when you get a gas leak use a Halight detector . There are some basic ways of charging a system that are on capillary. I cant imagine a Coke Fridge being on anything else . Charge it up till it floods back without the fan on that will do it. And yes that unit looks a little large but you havent given enough info on the evap size etc .
    Jun 2005
    S****horpe
    135
    This is a hydrocarbon refrigerant very much like Care 30. I think OGB is right, you need to get this checked out before you use it, the macine may not be suitable for flammable gases.
    It's a lovely day to pump some gas
    Jan 2006
    192
    Quote Originally Posted by Johnny Rod
    Yes well I was joking about the propane based refrigerant gas . Although there was an attempt to market that type of gas in OZ it has a died a natural death I hope . Obviously the coke machine owner is a backyarder and having a crack at making his machine work .
    Unless he gives evaporator details theres no point and trying to work anything out . Is there ?
  1. Water in *****
    By chemi-cool in forum Refrigerants
    Last Post: 17-08-2009, 10:16 PM
  2. Elderly Ice cream machine.
    By Onthecut in forum Trouble Shooting
    Last Post: 20-11-2005, 11:31 AM
  3. Adding *****
    By M Kalisher in forum Domestic
    Last Post: 12-05-2003, 05:20 PM
  4. Cattabriga Ice Cream Machine
    By Abe in forum Trouble Shooting
    Last Post: 26-04-2003, 01:06 PM
  5. Soft Serve machine won't shut off
    By terrygoodrich in forum Commercial
    Last Post: 14-10-2001, 01:02 AM
