    Budget Host's Avatar
    Budget Host Guest
    Question Scottsman CME 506 Ice Machine
    Hi all!
    I have Scottsman CME 506 Commercial Ice machine, The Compressor is not starting and Bin full light is flashing even after change an electronic bin full sensor. I found burnt wires going from auto electronic controller to Contactor and motor pump.
    Any Ideas?
    Thanks.
    BudgetHost@msn.com
    Aug 2004
    49
    13
    Re: Scottsman CME 506 Ice Machine
    Blinking light? Usually light is steady, or off. If you remove the optic "eyes" where the ice breaks the beam, you will usually find they are very dirty. You can clean with a descaling solution (for ice machines) and gently clean the "eyes". Don't scratch them. Start there at least.
    Burnt wires as in just discolored, or totally burnt to a crisp? Pictures would help.
    Jun 2005
    Stoke on Trent
    588
    The eye assembly are cheap enough to just replace, I think SRW had the cheapest Scotsman parts.
    ccrsedona's Avatar
    ccrsedona Guest
    sounds like the controller is smoked, you will probably have to replace it and the burnt wiring plugs & wires
    Budget Host Guest
    Thanks all for replies. I have replaced a set of eyes but bin full light is still blinks and steady. Is there any place I can find Scottsman Parts Cheaper or Used parts in USA?
    Thanks.
  1. Manitowoc Ice machine taking too long to harvest..
    By nyTroX in forum Trouble Shooting
    Last Post: 08-05-2011, 09:39 PM
  2. Elderly Ice cream machine.
    By Onthecut in forum Trouble Shooting
    Last Post: 20-11-2005, 11:31 AM
  3. Cattabriga Ice Cream Machine
    By Abe in forum Trouble Shooting
    Last Post: 26-04-2003, 01:06 PM
  4. start refrigerating machine
    By QQQ in forum Trouble Shooting
    Last Post: 29-01-2003, 07:53 PM
  5. Soft Serve machine won't shut off
    By terrygoodrich in forum Commercial
    Last Post: 14-10-2001, 01:02 AM
