Results 1 to 14 of 14
Thread: testing thermostat
18-04-2006, 04:58 PM #1
testing thermostat
I am in the process of bringing my kegerator back to life and want to test the thermostat. Does anyone know how to do this? It is sitting on my desk in front of me...do I need to have this connected to the unit to run the test? Can I just use and ohm meter?
Thanks for your help,
jerry
18-04-2006, 07:39 PM #2
Re: testing thermostat
If its just got contact switches, use ice
18-04-2006, 07:44 PM #3
Short circuit the 2 leads on the thermostat.
18-04-2006, 09:52 PM #4
There aren't any leads. It is just the two metal contacts coming out of the thermostat. What does the ice do?
18-04-2006, 10:13 PM #5
Originally Posted by psrome
If you haven't got ice to hand along with a thermometer try attaching it to another fridge that is working and test it then.Brian - Newton Abbot, Devon, UK
18-04-2006, 10:24 PM #6
I am for the confustion but the thermostat is disconnected. Is there any way to test it without power. Like an Ohm meter?
Thanks for all your help thus far.
18-04-2006, 10:34 PM #7
Originally Posted by psromeLast edited by phil68; 18-04-2006 at 10:43 PM.
Noah had to leave the dinosaurs behind as they would've sunk the boat.
18-04-2006, 10:47 PM #8
Thank you very much guys. I will get this puppy running one of these days.
19-04-2006, 12:27 AM #9
There is 2 connectors on the top ...? yes?
is there a long silver thin pipe coming out of it as well?
(just making sure you havent removed the phail)
Ice will not activate it, put the end of the little pipe (phail) into a freezer and you will hear a click. It should now go open circuit (billions of ohms) .
now warm up the phail and it will click again it should have a closed circuit.
Why do you think the stat is faulty?
and go get a cuppa
19-04-2006, 02:33 PM #10
I finally figured it out...
The thermostat is good, the compressor is good, it was just a bad connection. I shouldn't say I figured it out...my neighbor, who is in the refrigeration business, called one of the techs. for the company and had him walk him through testing. Come to find out my neighbor had me cut the pipes to my compressor, drain my refrigerant, and dismantle my thermostat just because of a bad electrical connection. Oh well, I learned a lot and he is getting tech. over to put it all back together for me. He is quite embarrassed.
Thanks for all your help guys. I am sure I will be talking to you all again some time in the future.
Jerry
19-04-2006, 03:48 PM #11
LOL. .Takes a licking, keeps on ticking.
20-04-2006, 02:07 PM #12
ALWAYS - ALWAYS - ALWAYS go for the simpler checks first.
Never presume that an item is OK - check it and then move on to the next.
Paula
07-08-2006, 05:06 PM #13
Where you get it???
07-08-2006, 09:21 PM #14
I certainly hope you mean water coolant as releasing refrigerant is a mega No no in the states there.
Pressure testing for leaks on split a/c systems
By mrchatts in forum Air ConditioningReplies: 46Last Post: 08-04-2010, 10:02 AM -
Thermostat compatibility
By Frusciante in forum DomesticReplies: 6Last Post: 10-04-2006, 11:43 PM -
procedure for chillers testing......
By drk_in in forum FundamentalsReplies: 2Last Post: 17-02-2006, 08:47 AM -
H.P switch testing
By bernard in forum Supermarket RefrigerationReplies: 21Last Post: 10-06-2005, 09:50 PM -
noobie question re testing compressor
By aaron cadell in forum FundamentalsReplies: 19Last Post: 28-04-2003, 08:37 PM
