Thread: Door Seals!!
27-03-2006, 06:11 PM #1
Door Seals!!
Iam ususally involved in Air Conditioing but my company has taken on some kitchens.
I have a problem installing door seals on foster freezers. I start by putting the seal in each of the four corners then push in the sides.
The problem is that after a few days the sides start coming out of the groove. I ve tried pressing them in but the seal appears to be too long for the fridge door (it puckers in the middle)-
Ive given up today as my thumb hurts but will return to site tommorow (fitting new drain heater)- any tips on door seals??????
27-03-2006, 07:54 PM #2
Re: Door Seals!!
always a pain to fit DG's always seem too big for the frame. I usually start at a top corner and get half way down then push it up so the bottom corner lines up.
Still doesn't always work mind.
We have a customer with 4 restaurants whcih need approx 50 gaskets between them. I for one don't fancy it so currently investigating these chaps
http://www.seal-it-uk.co.uk/
cheers
richard
28-03-2006, 07:51 PM #3
Re: Door Seals!!
Originally Posted by aeb200
cheers
Steve
29-03-2006, 08:09 PM #4
Re: Door Seals!!
Cheers Steve
I'll try the fairy liquid in a hot bucket of water-see if it works
regards alex
04-04-2006, 11:35 PM #5
Re: Door Seals!!
The hot water usually seems to do the trick.
If it was easy everyone would do it.
