Thread: Broken seal in TXV
12-03-2006, 09:52 AM #1
Broken seal in TXV
I have a problem with a TXV Alco used on a air to water heat pump. I have found the seal, on several machines, broken many times when on heat mode. Does anyone have any idea why this could be happening?
13-03-2006, 05:44 AM #2
Re: Broken seal in TXV
I would say it's a combination of high heat and pressure.
14-03-2006, 01:27 PM #3
is it suitable for the application and chosen refrigerant,could it be its for cooling only,not heard of that before but it does not like something,whats the seal made of??
14-03-2006, 08:23 PM #4
Thanks for your answers guys. The valve is the original from the manafacturer as is the refridgerant. The seal is made of neoprene, if I'm not mistaken.
Frick Premature Seal Failures
By Steve Wright in forum Industrial CompressorsReplies: 32Last Post: 11-06-2010, 02:34 PM -
Help needed in Venezuela.
By El Tel in forum IndustrialReplies: 9Last Post: 15-03-2010, 10:54 PM -
Seal display unit
By Andy AC in forum Trouble ShootingReplies: 4Last Post: 17-08-2006, 10:45 PM -
Broken compressor
By Peter_1 in forum Industrial CompressorsReplies: 19Last Post: 12-09-2004, 02:28 AM -
Bock AM5 compressor's shaft seal failiure
By Gareth in forum Trouble ShootingReplies: 11Last Post: 05-04-2004, 09:12 PM
