Results 1 to 9 of 9
Thread: Old Sporlan TraxOil Control
11-03-2006, 12:35 AM #1
Am looking for some documentation on the Sporlan version of the TraxOil control. My Google searches give me nothing. I understand that they are no longer in use as Alco now sells a version and Sporlan is out. Situation is that I have 2 compressors with these on them (same system) giving me problems which are the opposite of one another. 1 is constantly trying to drain but will not and the other is constantly trying to feed and won't. I have taken both of them apart, totally cleaned screens and working parts. Only difference noticed was that when I put pressure (nitrogen) to feed and drain ports. 3 show no pressure through the port on the body of the of the control while one does. These will be changed out for your standard oil pots, but I would really like to know the specs for the ports on these things and if anyone out there has run into this before!?
Only A Refrigeration Mechanic,
Not A Brain Surgeon!
11-03-2006, 04:48 AM #2
Re: Old Sporlan TraxOil Control
I don't understand how a traxoil is constantly trying to drain. All a Traxoil is designed to do is to feed. I don't understand your question, but you happened to ask it at the end of a week where I am replacing 5, ZF48's in a Costco.
I am not shy, however, to state that the Traxoil is a piece of **** and should not be attached to commercial refrigeration equipment that does not otherwise have oil safety devices.
I think the original design was Australian. Some patent disputes and thus transfers from Sporlan to Alco to Emerson. And then a pretension of a safety device with the OMB model, which at least turns a compressor off, compared to letting it grind itself into magnetic magic to assist in the failures of all other attached compressors.
I somewhat feel better now. Thanks for asking.
http://www.emersonflowcontrols.com/w...ut%20Sheet.pdf
11-03-2006, 05:44 PM #3
I have seen the Alco version of the trax oil and know that there is only a feed line with solenoid. This old Sporlan version has 2 solenoids and is set up to drain and feed.
11-03-2006, 09:25 PM #4
drain from where?
12-03-2006, 03:43 AM #5
Here is a quick drawing of what this control looks like.
12-03-2006, 07:58 PM #6
I never saw that version. Interesting. Hussmann racks would use an equalizing line to keep off-cycled compressors from filling with oil, but I never saw a solenoid operation as a part of it.
12-03-2006, 09:58 PM #7
Yeah I know. The drain line has been terminated. Anyways like stated before, these will be changed out. I was just trying to see if anyone else out there had seen these.
31-03-2006, 03:59 AM #8
On hussmann racks the OMA should be used on semihermetics and OMB only on scrolls. Semis use too oil for the OMB ports to keep up.
31-03-2006, 05:06 AM #9
Airwell Florida Inverter Air Condition - in need of help
By AndY1 in forum Air ConditioningReplies: 21Last Post: 05-07-2008, 10:48 AM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
Searle cellar cooler control problem
By iceman007 in forum ElectricalReplies: 6Last Post: 06-07-2004, 08:57 PM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM -
Spolan OilMaster
By Richard in forum New TechnologiesReplies: 7Last Post: 22-11-2002, 08:43 AM
