Results 1 to 47 of 47
Thread: Chillers
17-03-2006, 03:18 AM #1
Re: Chillers
Originally Posted by NoNickName
You could also use a high performance butterfly valve with a motorized actuator. On start-up the valve opens. On shutdown the valve closes. Very low pressure loss during operation.
no oil cooler, because it is not required, according to the compressor manufacturer literature. If I had an oil cooler, refrigeration dilution would be even worse.
In some cases you have to add a heat exchanger in the suction line to specifically superheat the suction gas.
Absorption chillers
By bhahmad in forum TransportReplies: 7Last Post: 31-03-2007, 04:14 AM -
Liquid Chillers
By elmusasc in forum IndustrialReplies: 2Last Post: 18-05-2006, 11:06 PM -
procedure for chillers testing......
By drk_in in forum FundamentalsReplies: 2Last Post: 17-02-2006, 08:47 AM -
Chillers versus packs
By Peter_1 in forum Technical SpeculationsReplies: 15Last Post: 17-01-2004, 09:48 PM -
Centrifugal chillers
By reggie in forum Industrial CompressorsReplies: 2Last Post: 02-05-2002, 07:22 AM
