Results 1 to 21 of 21
Thread: I need a cute idea
08-03-2006, 01:51 PM #1
I need a cute idea
2 hermetic compresor (Maneurop type) conjoint in parallel in a system air-water.The system has 4 group.
The third group has both of 2 compresors burned (not the motor windings), propably mechanicals parts are stucked. If anyone has any clou about what happened there please reply me.
08-03-2006, 06:11 PM #2
Re: I need a cute idea
A mouse nest inside?
10-03-2006, 07:13 AM #3
Peter_1 )))) ((((((.
14-03-2006, 11:14 AM #4
Is it oil burn out?For certanly is oil but you must to test it on acids etc.Did you have some problems of overload on that machine?
Renato
15-03-2006, 10:03 PM #5
Hi Dias, if the compressors are in the same circuit the oil is contaminated. You have to flush the system. Give me some more details if you can.
15-03-2006, 10:23 PM #6
When two compressors are in parallel and one of the two burns, the second is doomed in days
18-03-2006, 04:13 PM #7
maybe one has been starved of oil,siezed then burntout,then thats contaminated the other whitch has the got acid contamination and burnt out asswell,have they got a oil feed system on?
18-03-2006, 04:44 PM #8
Originally Posted by dias
How do you know they're burned and how do you knwo it aren't the windings?
What is the resistance readings of the windings?
Resistance between windings and ground?
Mechanical parts are stuck... how do you know this?
Is there an electrical failure or a mechanical failure?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
19-03-2006, 09:22 AM #9
is this a trick question ? if its burnt,burnt out,toasted,whatever thats the windings gone walkies yes,any readings to earth are fatal,any reading accross the start and run windings will be relative to the size of the motor,if all that reads out o/k its either siezed,somethings come adrift or even the starting kit[1phase] or check the contactor and incoming voltage[3 phase] on that all three windings should read out equal.
19-03-2006, 10:16 AM #10
That surprised me also, it's burned but not the motor windings.
Think that's the reason why nobody's responding.
Think Dias isn't reading any longer this thread.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
20-03-2006, 12:54 PM #11
old_gas_bottle
it’s not a trick question . I have do the electrical check of 3 phases and the incoming voltage.it's ok.
Peter_1
I have do the measurements of resistance of the windinds and the resistance between windings and ground. It’s ok.
Mechanical parts are stuck because I hear (different noise of normal) the compressor to run but the pressure of r22 not change.
20-03-2006, 02:20 PM #12
So you have a bypass or the spirals are broken, maybe due to a liquid hit
24-03-2006, 09:55 PM #13
You mean that internal parts are destroyed
24-03-2006, 11:18 PM #14
Originally Posted by Nicolás Vera V.
25-03-2006, 06:02 PM #15
Originally Posted by NoNickName
You mean the inner supporting springs?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
25-03-2006, 07:22 PM #16
No, I mean the spirals, though for some reason I thought we were talking about scroll hermetic by Maneurop.
26-03-2006, 06:32 AM #17
Check for debris or liquid refrigerant returning to the compressor.
26-03-2006, 01:02 PM #18
And I forgot Maneurop also had scrolls
26-03-2006, 06:51 PM #19
If the motor is running and the pressure does not change the valves are broken if it is a reciprocating compressor.
The parts are not stuck, the compressor is simply not doing any work (compressing).
01-04-2006, 07:46 PM #20
try switching two phases and see what happens
Suc6
Victor
02-04-2006, 11:06 AM #21
Oh yes It could be running the other way around.
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
Will this work or do you have a better idea?
By friesr in forum Technical DiscussionsReplies: 18Last Post: 24-06-2006, 10:18 AM -
is this even possible??
By Tycho in forum New TechnologiesReplies: 2Last Post: 05-05-2006, 10:20 PM -
new ice making idea
By ice builder in forum FundamentalsReplies: 13Last Post: 30-04-2006, 10:27 PM -
New idea for higher efficiency
By star882 in forum New TechnologiesReplies: 7Last Post: 22-02-2006, 04:22 PM
