Thread: Secondary Glycol leak
18-11-2013, 12:47 PM #1
Hello All
What an awesome site.
I have a secondary glycol system in a supermarket that has a small leak. We are unable to trace the leak as the glycol is transparent, is there any way of adding some sort of dye into the system?
18-11-2013, 01:08 PM #2
Re: Secondary Glycol leak
Hello Terry and welcome to the forum.
Have a look here for food grade dyes which can be added to your water/glycol circuit.
They have a distributor in Johannesburg
21-11-2013, 09:20 PM #3
You can also pull samples of the condensate drain water and put it under a Refractometer. This way you can find the circuit that is leaking, then go case to case.
Good Luck.
21-11-2013, 09:24 PM #4
Expensive stuff that Frank
Especially if its a large system, chuck in some drain tracing dye and you will find it.I love the smell of Ammonia in the morning!
26-11-2013, 09:30 AM #5
We have managed to find the leak...yeah!
I will be looking into purchasing dye as the system is large and I wouldn't want to run around as before.
Thanks for all the input
