Thread: Split system no sirculation ?
Threaded View
11-11-2013, 03:42 PM #1
Hi all,
New here so please bear with me.
I have a Ecoair split system about 15month old, model ECO1211S
It seems to work ok in cooling mode but in heat mode after 30min running the gas line from condenser is too hot to touch but no heat from indoor unit. Gas line at indoor unit is only luke warm. If left running outside unit starts to squeal so I have to shut it down. Was told it’s likely to be refrigerant loss but when a retired engineer checked he said the pressures seem normal.
No damage anywhere to lines so what would stop the circulation ?
Someone else said its rubbish so scrap it, just naffed that it is out of guarantee.
One or two pointers as to what to look for would be much appreciated.
Thanks in anticipation.
