05-03-2006, 01:12 PM #1
5h Main Bearing Removal And Inserts
What Is The Procedure Of Removing And Inserting The Main And Pumpend Bearings For 5h46 Carlyle Compressor . Pls Explain In Detail, Better If Thereis Any Picture Of Procedure....and What Tool Is Used For Removal & Inserting Bearing, Where It Is Available, Also Any Website Too See It...pls Help.........
06-03-2006, 01:32 AM #2
Re: 5h Main Bearing Removal And Inserts
Are the mains a friction fit?
06-03-2006, 01:08 PM #3
MAIN BEARING I mean is a shaft seal end bearing and the rear bearing which is a pump end, and the tool i need is must be a hand operated. as i want to fix it on site, without moving the compressor.
06-03-2006, 02:57 PM #4
To my opinion, a visit on the Carlyle site might be of help, select Reciprocating compressors and the 5F/H models from the link;
http://www.marinesystems.carrier.com...TI9617,00.html
07-03-2006, 02:06 AM #5
Go here http://www.carlylecompressor.com/Fil...up_Install.pdf
look at fig 47 and 48 This is the same as a Carrier 5H46
07-03-2006, 04:54 AM #6
The bearing puller looks similar to a puller used for camshafts in engine building.
By altaf22m in forum IndustrialReplies: 1Last Post: 06-03-2006, 09:15 PM
