21-08-2013, 06:49 PM #1
Compressor shaking after air conditioner shutting down
hi
i received an old LG heatpump split ac unit
that had leakage because of cracked capillary tube
i cut 1 cm of the capillary then i weld it
made vacuum for 30 minutes then
charged it by weight
and it cool very good
problem is that when i shutting down them unit
compressor keep shaking for sometimes
30 seconds
5 seconds
and sometimes not
what is the problem or that is ok
in this video compressor shake up for 3 second only
21-08-2013, 08:27 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Compressor shaking after air conditioner shutting down
Refrigerant is expanding from high pressure side and turns motor backward until pressure equalize. Faulty (stuck) discharge valve at high side.
21-08-2013, 09:05 PM #3
http://www.ra.danfoss.com/TechnicalI...A5.02%20vs.pdf
fit another non return valve on the discharge line- stop the rattlin and prevent pipe fracturing
make sure u fit it the correct way round
21-08-2013, 09:10 PM #4
ok
if i left the unit working at this way
what will happen except rattlin & pipe fracturing
21-08-2013, 09:11 PM #5
more repairs, and more posts on here!
25-09-2013, 08:11 PM #6
ok
the solution installing discharge line check valve
thank u all
