Results 1 to 15 of 15
31-07-2013, 12:49 AM #1
LG floor standing 4 ton strange sound
hi
i have 4 ton LG floor standing
its works perfectly
but there is loudly sound from compressor
the compressor is reciprocating type
http://205.196.121.141/nafp3uhu31ug/...o/MOV_1021.mp4
Re: LG floor standing 4 ton strange sound
If it works perfectly, I would check for vibration.
31-07-2013, 11:55 AM #3
its only make loudly sound
and vibration is low
is there any problem if the vibration is high ( i know it may damage the componetent and may lead to leak)
but i mean if vibration is s danger to compressor or not
Normally it is the compressor that causes other components to vibrate and possibly fail.
What is the model # of the outdoor unit?
Does the compressor run hot? What are the operating pressures? I would recommend doing a pump-down test.
With single cylinder hermetic compressors I have had the motor come loose from its support and also the mounting supports come loose/apart inside. This makes a loud noise but it is usually followed by no cooling as the internal vibration causes the discharge line to break inside the hermetic. I should mention that the majority of these failures where regarding customers that used a hermetic compressor in a home-made transport application.
31-07-2013, 05:13 PM #5
the unit cooling very well
but the probleM IS only in the loudly noise
the unit model number is
LP H508TAO
31-07-2013, 05:34 PM #6
What kind of noise?
Is it metal grating on metal sounds?
Is it metal hitting metal sounds?
Is it a screeching sound (high pitched)?
Is it a low rumble (low pitch) sound?
Is it all the time or just occasionally?
Have you tested the fan motors to prove it is not them?
Rob
31-07-2013, 05:44 PM #7
31-07-2013, 09:42 PM #8
should the compressor have an insulated acoustic jacket- like uk units, check rubber mounting feet rubbers are ok, not perished, also check for compressor pipework rattling near the casing- last resort- set up a market stall selling ear plugs- you'll be minted!!!
31-07-2013, 09:58 PM #9
31-07-2013, 11:07 PM #10
Sadly your movie does not help at all as the unit covers are on, personally I can't hear anything wrong.
01-08-2013, 07:12 AM #11
06-08-2013, 01:01 PM #12
today i opened the cover and turned on the unit
here whaat i discovered
the compressor was repalced from scroll to reciprocating before 2 yeasrs
the recent compressor wasnt new
it was burn out then repaired and welded then installed
its works perfectly but only make loud sound
06-08-2013, 01:12 PM #13
here is the video for the compressor
06-08-2013, 09:02 PM #14
fit correct compressor and you can stick that 1 in that 4 ton craft unit!
08-09-2013, 09:39 PM #15
thank u all
please close thread
