Thread: CARRIER HAP Help
11-07-2013, 07:54 AM #1
CARRIER HAP Help
I have a project which is a 20 storied building and 2 sides of this building is covered with curtain wall.
Now I am unsing carrier HAP to calculation the cooling load but i dont know where to make the input for curtain wall. Their wall construction does not show anything like this.
Can someone help me on this regard?
11-07-2013, 09:39 AM #2
Re: CARRIER HAP Help
Yes, the default list not contains the curtain wall data, but if you know the wall physical data such as r-value, thickness, specific heat and weight, you can modify the name and input data.
11-07-2013, 10:09 AM #3
But there is no input option for reflectivity , which is a very important parameter for curtain wall.
12-07-2013, 02:40 PM #4
i am out of office,next working day i will update you after play with this program.
