Thread: Interlock lossnay mitsubishi
06-07-2013, 01:39 PM #1
Hiya,
Anyone know how to link lossnay unit to a split system working on a par 30?
06-07-2013, 04:47 PM #2
Re: Interlock lossnay mitsubishi
theres a cable with the lossnay to hook it up to a mr slim indoor and use that controller for lossnay functions
08-07-2013, 04:04 PM #3
As per above - It's the cable that is always supplied with the install manual taped to the top of the Lossnay.
This plugs into CN2L on the indoor pcb, (on your split) connect a 2-core 0.75mm CY cable from this onto your Lossnay and connect to TM2 terminals 1&2 on the Lossnay pcb.
Go into service mode on the PAR-30 and into function settings. Select Mode 2 to setting 2 (for without lossnay outside air onto indoor unit) or setting 3 (for lossnay outside air onto indoor unit) depending on your fresh air setup.
16-07-2013, 10:50 AM #4
Thanks guys
