Thread: Osaka A/c
12-02-2006, 10:13 PM #1
Osaka A/c
Anyone got any info on Osaka A/C units? Got a cassette unit, hardwired remote control, keeps switching itself off intermittently. Not sure if timer built into controller activated. Lost for ideas, any help appreciated.
12-02-2006, 10:58 PM #2
Re: Osaka A/c
Hi mate,
I have not worked on an Osaka before. Have you checked the drain/pump as this is the most common fault with air con units switching themselfs off.
and go get a cuppa
14-02-2006, 06:59 PM #3
Re: Osaka A/c
Thanks for reply. No condensate pump fitted(not even internal lift pump).
14-02-2006, 10:24 PM #4
Re: Osaka A/c
There might not be a pump, but is there a float switch?
If this is activated and water is not flowing away then it will shut down the unit.
After a few hours water will dry up and you will be able to switch it back on again.
and go get a cuppa
