Thread: Daikin VRV E9
18-06-2013, 06:04 PM #1
Daikin VRV E9
Hey guys
Got a daikin VRV r407c with E9 had daikin come and look and told us to replace EEVS replaced all EEVS and still the same fault. swapped boards over with another unit reset same fault?! what else is there to change?!
cheers
18-06-2013, 06:31 PM #2
Re: Daikin VRV E9
It could be the out door PCB at fault not sending the signal it monitors the voltage to the heads
18-06-2013, 07:18 PM #3
18-06-2013, 08:11 PM #4
Re: Daikin VRV E9
strainer gauzes-good luck
19-06-2013, 10:00 AM #5
Re: Daikin VRV E9
Weve swapped outdoor boards put new heads on put new cables? Even daikin are confused
19-06-2013, 06:44 PM #6
Re: Daikin VRV E9
That's a hard one to work out . If daikin don't know. then its going to be down to them to work it out . Could be a fault that no one has come across for before . Let us know what happens good luck
19-06-2013, 08:04 PM #7
Re: Daikin VRV E9
try to check gas senzor pipe and suction senzor pipe it`s posible one of them to be out of parameter.
