Results 1 to 11 of 11
Thread: Worst unit for fitting belts on?
01-02-2006, 07:38 PM #1
Spent a good hour today trying to get a set of belts on a TS500.
I'm sure it will be a lot easier next time now I know what I need to do but it set me wondering what the worst unit ever is for fitting belts on?
Any suggestions.
01-02-2006, 07:48 PM #2
Re: Worst unit for fitting belts on?
Originally Posted by djbe
Petter P6-500, took all morning to get the doors off let alone change the belt.
SNWD Version with 2 fan belts, pain in the bum to get tension on both right. Single belt one was easier just snot the tensioner pulley.
SMX Water pump belt (Before they introduced the opening door)
SMX Early type before belt guides introduced, main belt (78-826) goes loose and also then have to change rear water pump hose.
TR1000/Genisis comp belts that according to carrier JUST SLID OUT !!! when you tale the clutch off the flywheel.
Could go on but begining to sound like a grumpy old mobile engineer
Ray
02-02-2006, 12:27 PM #3
2nd vote for SMX water pump (early with air filter by alt).
John.
02-02-2006, 02:21 PM #4
bahh, 6500's were a piece of p*** along with nwd,snwd.
Have not really seen many of the latest TK units to comment on that but never had a problem with Smx.
By far the worst so far for me has been a merc vito, 3am, freezing cold service station, it's easier in the day.
02-02-2006, 09:05 PM #5
[QUOTE=alpha]
Good old mercs. with a poly vee. Take the belt off thinking I'll remember how to put this back on, interrupted by the phone, come back and there goes a few hours trying every which way but the right way
02-02-2006, 09:49 PM #6
LOL Try a 16 cylinder compressor with 8 belts to get even tension and alignment... worse still a shaft seal change on one... takes two of you to lift the flywheel ..... and that does not include the belt guards...........
:cool: Calvo :cool:
02-02-2006, 10:58 PM #7
djbe, a hour ! engine chain bit tight then, i always wip off the exhaust....no skinned knuckles
02-02-2006, 11:10 PM #8
03-02-2006, 05:59 PM #9
Originally Posted by andy towle
Like I said it will be a lot easier on the next one (as proved to be the case yesterday).
Mind you it doesn't help when the customer insists on having Scania roof spoilers fitted so you are trying to do everything arse about face from the roof of the body.
03-02-2006, 07:26 PM #10
Originally Posted by Lazarus
04-03-2006, 09:07 PM #11
NWD's, SENTRY 50 series.... all easy stuff. Has anyone ever changed belts on RC II's or Super II's or SLR 50 series. Try a water pump belt on a early Carrier T-bird, the one with the small doors?
Hatefull reefers.
Daikin a/c units.
By rick in forum Air ConditioningReplies: 59Last Post: 18-02-2008, 09:22 PM -
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM -
M I T S U S H I T A ac unit with no condensing unit
By Chinua in forum Air ConditioningReplies: 2Last Post: 28-07-2006, 06:54 PM -
Matching Evaporator with Condensing Unit
By Abe in forum Technical DiscussionsReplies: 12Last Post: 25-07-2001, 08:57 AM
