27-03-2013, 06:07 AM #1
Clint Package plant Compressor failure ..? Help please.
Good day everyone.
I have a problem with new Clint package plants that keep losing compressors.
Clint Plants.jpgThe middle and 1st compressors inline burnt out. We have lost these compressors on 3 different plants with no clear reason ...? Units are serviced every month and are only a year and a half old. could it be the way the compressors are lined up that the 1st 2 compressors runs hotter than the last (bull heading maybe?)
there are was no refrigerant leaks or any other major problems and now suddenly during the hot summer we are having problems.
please any advise will be greatly welcomed.
Roan
27-03-2013, 07:59 PM #2
Re: Clint Package plant Compressor failure ..? Help please.
Are there internal discharge check valves on these compressors? Also have you a common equalised oil line between the compressors. Any feed back on what caused the compressors to fail, electrics or oil related?
alecMostly found in the southern part of this green and pleasant land.
28-03-2013, 06:22 AM #3
Hi Alec,
Not sure on the internal check valve on the compressors, but I don't think so. there is an equalized oil line between the compressors. No feedback yet on the cause but I think it was electrical as all the compressors are down to earth. another strange thing I have noticed is that the compressors are discolored like they heated up before they bummed out. I also can't see any protection to prevent this.
28-03-2013, 06:39 AM #4
Hi Roan,
Which operation mode of unit? HP?Last edited by bigor_2; 28-03-2013 at 12:13 PM.
