Results 1 to 8 of 8
Thread: Capacitor Start Motor
26-01-2006, 05:17 PM #1
I am working on a GE capacitor start motor. I am trying to reverse direction. Ohm readings are: white to blue 2.5 ohm. orange to yellow 2.5 ohm. orange to red 7.3 ohm. red to yellow 9.6 ohm. i figured blue to white is run, yellow to orange is run, and red to yellow is start this is the set up i have for counter clockwise. I am trying to reverse to clockwise and am having trouble. Checking to see if anyone has any suggestions. This is the first cap start motor that i ever worked on and am still a student and in the field, any suggestions would be greatly appreciated........Thanks
26-01-2006, 06:14 PM #2
Re: Capacitor Start Motor
Have a look here for some help...
http://www.owwm.com/files/PDF/FAQ/ElectricMotors.pdf
or here..
http://en.wikipedia.org/wiki/Electric_motorLast edited by Brian_UK; 26-01-2006 at 06:19 PM.
26-01-2006, 10:17 PM #3
You have to switch a capacitor in series with the running winding.
Do once a search on this forum for the schematics posted by MarkFiddy of an Annie strarting case and try to understand these schematics.Last edited by Peter_1; 26-01-2006 at 10:21 PM.
27-01-2006, 06:36 AM #4
The 'other' side?
Just in serie, the other side is the common.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
27-01-2006, 06:47 AM #5
The cap start motor is 120 vac.
27-01-2006, 08:10 AM #6
can you simply pull the rotor out and put it back in the opposite direction?
27-01-2006, 06:33 PM #7
Originally Posted by Peter_1Brian - Newton Abbot, Devon, UK
27-01-2006, 07:17 PM #8
Originally Posted by bryan2392
Fan motor over heating & Shuting down.
By Rookie in forum DomesticReplies: 15Last Post: 30-06-2005, 11:21 PM -
Fan Motor
By Coolie in forum Technical SpeculationsReplies: 38Last Post: 16-02-2005, 08:03 PM -
Evap motor no come on
By Apprentice in forum Technical DiscussionsReplies: 13Last Post: 04-12-2003, 04:07 PM -
Motor Oil vs Refrigerant Oil
By zolar1 in forum Technical SpeculationsReplies: 8Last Post: 26-11-2003, 12:43 AM -
current draw on condenser fan motor
By dan wong in forum Trouble ShootingReplies: 15Last Post: 25-05-2001, 06:12 AM
