    Apr 2012
    Iraq
    35
    623
    the check valve in airconditioning
    hi
    what is the utility of check valve between the compressor discharge and the reversing valve
    May 2010
    W.Yorkshire
    31
    To ensure correct flow direction of refrigerant.
    (If i have understood the question.)
    Feb 2007
    2,473
    45
    Re: the check valve in airconditioning
    To prevent migration of refrigerant to the compressor head during the off cycle.
    3,856
    If its a rotary compressor it will also stop it spinning backwards when the system turns off.
    Apr 2012
    Iraq
    35
    623
    thank u all
    please close the thread
