04-03-2013, 09:12 PM #1
Stulz CCU ~ 30mm drain pipe connections ~ Adapter?
Hi, there.
Stulz kit is German and, over there, I guess 30mm plastic/etc is a common size of pipe for connecting up to the humidifier drain outlet.
In UK, however, 30mm outside dia (OD) is a bit odd and connecting up to that drain is a bit of a problem. As the humidifier discharge water can be near boiling point, the first thought is to run the drain in copper (unless someone can suggest a plastic pipe/hose supplier). But UK copper plumbing pipe is 35mm od. Mind the gap.
My thoughts are to go with a 35x32 compression connector (metric to imperial) and tighten down the imperial-sized olive until it grips the plastic. Hopefully it would take up the 2mm gap(?) But I thought I would check with the savy engineers on RE in case anyone has come up with this issue before and can suggest the correct adapter, or a supplier of 30mm pip/hose+fittings that's good for near boiling water.
Any ideas/suggestions?
04-03-2013, 09:41 PM #2
Re: Stulz CCU ~ 30mm drain pipe connections ~ Adapter?
plumb ctr and b and q do a flex seal- a 3 inch peice of rubber with 2 jubilee clips to marry up both ends good for 3 bar pressure, also they can go up a size too
http://www.flexseal.co.uk/products/p...plumbing-rangeLast edited by install monkey; 04-03-2013 at 11:22 PM. Reason: link added
04-03-2013, 11:18 PM #3
Or poor a bit of glue on the pipe, light it up and force over fitting, remove and allow to cool and hey presto instant adapter, works great on those Linde outlets
alecMostly found in the southern part of this green and pleasant land.
07-03-2013, 11:48 PM #4
Thanks for the ideas.
08-03-2013, 09:28 PM #5
Post a pic of your singed eyebrows, used to be right of passage here.
