    Dec 2008
    77
    137
    Smile vsw-h24b4/emr split air conditioner.
    hi guys and gals.has anybody had any dealings with these wonderful chinese air con units.i have a customer with one and the indoor fan stops and when the temp display drops to about 14 degrees c it starts up again.has anyone any ideas.cheers.doormaster
    3,853
    Re: vsw-h24b4/emr split air conditioner.
    Heating or cooling mode? Wonder if its stopping the fan in heating mode when coil temp drops due to other faults.
    Have had LG do similar when indoor coil sensor reading low.
    Apr 2012
    Iraq
    36
    623
    Oct 2007
    manchester
    5,639
    45
    check the return air sensor-usually behind the filter-could be picking up the influx in temperature in either mode causing a wide temp swing- stick it in cooling and hold the thermistor
