Results 1 to 12 of 12
Thread: Ammonia Heater
13-03-2013, 08:56 AM #1
Re: Ammonia Heater
"Additional the production people require the temperature in the room be 5º C and 85 % RH. So the fan could be of the very high capacity and you will raise the room temperature." If you have a lot contact heat exchanger surface between the product and the air I don't think so.
"May be he most simple thing is to install fancoils with a closed water circuit to keep the room at 5ºC"
If you don't want to use sea water directly (why?) you can use a titatium or cooper nickel heat exchanger to exchange between the sea water and a dry cooler, with sweet water, and this sweet water will warm up the air that passes through the product.To make progress is never good enough, I want to do better and better and better
