    archstanton's Avatar
    archstanton Guest
    Compressor Query
    Are there any compressors you can theoretically reverse rotation and still maintain compression?
    11,025
    Re: Compressor Query
    Yes, any three phase piston compressor; however you would need to check the oil pump for correct rotation on those with a pump.
    Oct 2003
    5,630
    34
    The commercial 3 phases pistosn (Bitzer, Copeland, Bock,..) can run in both directions.
    In the oilpump is some sort of a locking pin which makes this possible.
    May 2006
    India
    74
    399
    YES, PISTON COMPRESSORS OF bOCK MAKE CAN BE OPERATED IN EITHER DIRECTION.THESE COME WITH REVERSIBLE OIL PUMP.
    KORANNE
