Thread: City multi
13-12-2012, 10:53 PM #1
City multi
Trying to do an acid test on a Pury p250 yem-a city multi.anyone any idea how to get oil out without reclaiming gas.
13-12-2012, 10:58 PM #2
Re: City multi
connect a gauge line (no manifold!) haha- carrier/hrp do an acid,moisture test kit you connect to the system and it vents gas for a few minutes- never tried them so cannot gaurentee the accuracy- city multi's have oil seps on so not easy to get a sample of oil
13-12-2012, 11:02 PM #3
Re: City multi
Cheers.ye it's not looking good at least with a sanyo vrf there's a oil line port to take some oil from.
13-12-2012, 11:35 PM #4
Re: City multi
Line tap valve on the oil line after solenoid on compressor side.
14-12-2012, 07:56 AM #5
Re: City multi
Not sure about line tap valve they tend to leak after a while.
14-12-2012, 06:54 PM #6
Re: City multi
Climate ctr sell a 2 second acid test that you put onto a schraeder valve. Never used one so cannot comment on its accuracy.
Craig
