Thread: Ewpc 1000
12-01-2006, 03:07 PM #1
Ewpc 1000
I have a problem on a Eliwell EWPC 1000 controller the first three parameters are gone DIF LSE and HSE.Can somebody help with this problem
12-01-2006, 03:52 PM #2
Re: Ewpc 1000
Hi Geja,
The first three parameters are factory set as follows
Dif= 2 (this is the switching differential
LSE= -55 (lowest available setpoint)
HSE= 40 (Highest available setpoint)
Try this link for a datasheet on this controller
http://www.invensyscontrolseurope.co...eng_1-2000.pdf
Hope this helps
Luke
12-01-2006, 03:53 PM #3
Re: Ewpc 1000
what do you mean by gone?
13-01-2006, 06:52 PM #4
Re: Ewpc 1000
the parameters are delete on the controler, by programming it's start on parameter 3
Cooling down the water in a 1000 liter container
By Joep Hogenhout in forum Technical DiscussionsReplies: 29Last Post: 21-04-2009, 01:27 AM
