Results 1 to 11 of 11
Thread: problem with signal receiver
28-11-2012, 10:40 PM #1
Hello my friends.
I have a problem with an a/c and to be more specific the unit is not receiving the signal from the remote control.
I suspect that the problem lies with the electronic part on the circuit board that accepts the signal from the remote control.
How can I check if it is still on operation?
What measures should I do?
Can I use an other type of this electronic part?
Thanks in advance..
28-11-2012, 10:47 PM #2
Re: problem with signal receiver
test the remote operates by pointing it at ur camera phone and pressing the buttons, you will see the infra red eye flash- as for testing the receiver,dont know but they should be relatively cheap
28-11-2012, 10:52 PM #3
where can I find one receiver on the web?
28-11-2012, 10:59 PM #4
what make and model number?
29-11-2012, 06:06 AM #5
the a/c is not a famous one..probably it is made in china.
I do not know what the result would be in case I install an universal receiver.
29-11-2012, 05:01 PM #6
that's where the problem lies...the receiver...
29-11-2012, 05:05 PM #7
I do not how but after heating the connections ,on the board ,of the receiver,the latter re-activated...suspicious...
07-12-2012, 10:55 PM #8
Strange, but glad you sorted it!
07-12-2012, 10:56 PM #9
The make of the AC unit! It wasn't made by Gree was it?
08-12-2012, 04:12 PM #10
the make of the unit is "firstline".it was sold by a local super market called "carefour"
10-12-2012, 12:01 PM #11
Some units require a minimum remote sensor distance of 20 feet.Walk closer to the unit and try the command again.If there is any furniture in front of the unit or in front of the unit interface,move the furniture out of the way.If the remote control is close enough to and pointed at the unit,but still fails to operate,the batteries inside the remote control might be too weak to serve the appliance.I am sure you got the solution.Thanks.
