Results 1 to 9 of 9
    Apr 2010
    Australia
    11
    Wall Hung Split Spitting out water?
    Hi all,
    Any ideas on why a wall hung split would 'spit' out water while operating? Other Mechanics have checked over and no fault found. I'm yet to check over, just getting some info prior to my visit.
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Wall Hung Split Spitting out water?
    Undersized,high humidity,poor airflow,blocked drain,SOG.....
    Take your pick
    Stu
    Tool's ? check ! Condom's ? check !
    Nov 2012
    Australia
    blocked drain, cracked drip tray,
    3,853
    Dirty coil.
    Oct 2007
    manchester
    5,639
    45
    drain backing up with water,may be ok most of the time but backs up after heavy use, dirty gauze on condensate pump,as others say dirty fins on coil causing water to get sucked off coil,strip unit and use nitrogen or compressed air to blast coil, be careful when using nitrogen.
    Jul 2009
    stoke on trent
    48
    Make sure the blades on the fan impellar are not clogged with dirt. Common problem with wall mounts resulting in poor air flow.
    Dec 2011
    Australia
    69
    13
    low on gas causing slight icing up with a slightly dirty coil and high humidity ? does this sound likely ?
    Jul 2010
    scotland
    49
    71
    14
    I have had this on three differant wall units during the summer this year. Evaporator coil icing up, then when unit goes off, the ice melts and pours from between wall and unit, missing the drain pan. constant icing and melting. low charge.
    Quote Originally Posted by Simeonx1 View Post
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Then there is the mould and scum build up behind the evaporator in tropical climates. Condensate pathways clog up and start dripping from various points.
