Results 1 to 8 of 8
    Oct 2012
    london
    2
    Question Brand new Zanussi not working
    Hi all,
    I have recently moved into a flat that came with a brand new Zanussi ZRB229MWO which doesn't appear to be working. The flat was unattended for over a year before I moved in. So the kitchen appliances have been standing unused since Feb 2011 and only just switched on last week (25-Oct-12)
    I've removed sticky tape from the water outlet and switched the fridge freezer to the maximum setting on the dial. It has been on for over 5 days in total now and it's still warm inside both compartments(fridge & freezer).
    I've pulled the fridge out and looked at the back I can't see any obvious problems. When it's switched on I can hear a buzzing & also the fluid trickling around inside.
    Things I've tried:
    Turning it off at the mains and leaving it to stand for a while.
    Turning it off and on a few times.
    Any ideas? Have I missed something obvious in setting the machine up? Is there a way to reset the machine? I switched it off at the mains and left it to stand for an hour before switching it back on & still it stays warm inside.
    Oct 2012
    london
    2
    Re: Brand new Zanussi not working
    Thanks for your reply's
    I can hear a buzzing noise which I assume is the compressor. It's frost free as it has never been used. I'm in NW London, although I have someone coming around Friday to look at it, I was hoping there would be a simple solution that I could do myself.
    The motor appears to be the only part producing heat.
    Jun 2009
    Lusk , Dublin
    1,115
    Quote Originally Posted by pandoras View Post
    Check the heating coil of your Appliance if it is in working condition or not. For More information please visit www(dot)XXXXXXXXXX(dot)com.
    Stop promoting your website!!!!!!
    If you want to advetise do it through the propper channels!!!
    Stu
    www.p1ss0ff.com
    Tool's ? check ! Condom's ? check !
    Apr 2006
    55
    1,908
    30
    Hi Ninja
    would be best to google Airkool Domestics and give them a buzz as they will give you an honest quote and let you know if its worth repairing or not .... they also do a disposal service on nearly new equipment as they can recycle some of the parts so you can do your bit to save the planet
    R's chillerman
    If the World did not Suck, We would all fall off !
    Jul 2006
    norfolk
    737
    cheers chillerman
    check out my website www.airkooldomestics.co.uk
    ireland
    1,452
    41
    i never got a taste for spam, but i would also recommend airkool, always there with good advice and willing to help.
    al
    3,853
    I used to like spam but have stopped eating animals, used to do spammy grilled cheese.
    Apr 2007
    36
    371
    23
    Hey mate, Domestic stuff isnt really my thing but i highly recommend airkool...always provide a decent service and honest advice
