    Oct 2001
    Nottingham UK
    5,667
    Vehicle A/C Top-Up
    How to recharge you car on the cheap VIEW
    Dec 2010
    ZA
    154
    Re: Vehicle A/C Top-Up
    His next trick, how to drive to the ER with a set of missing fingers inexorably part of a welding glove...........
    Oct 2001
    Nottingham UK
    5,667
    I like the way he keeps shaking the can
    Dec 2008
    563
    Well done Frank, that was a good find. If only it was that easy.
    Bedford. Now retired and trying to relax.
    Sep 2003
    ISRAEL
    72
    4,248
    If he only knew that r-134 should be at liquid state before entering the system.
    He also answering your questions while you are watching....
    Jun 2009
    Lusk , Dublin
    1,115
    He also has the thermometer in the cab vent but the selector switch is set for demisting the windscreen.
    Stu
    Tool's ? check ! Condom's ? check !
    Dec 2008
    563
    I guess that we are all far too observant!
    I refuse to work on cars that the owner admits to self-charging, especially if they have used the leak stopper as well.
    The problem is, if they don't bother to tell you and you end up with gummed up gauges etc.
