Results 1 to 1 of 1
Thread: PVE oil in a Daikin compressor
14-08-2012, 08:35 PM #1
Someone can enlighten this a little bt?
In Daikin scrolls (VRVII and VRVIII) is PVE oil used instead of POE oil. PVE oil is non hydrolytic which should mean that this oil very difficult can transform to an acid in presence of moisture and high temperaures. You also can't use a POE acid tester to determine if the PVE oil is acid.
